car wont start
- MechaManZero
check the online manual on MX-3.com. The 95 has the same starter relay location most likely.
Çlark
![Image](http://i64.photobucket.com/albums/h192/Mechamanzero/MX-3/2mx3.jpg)
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
The starter relay or starter solenoid is the small box on top of the starter itself. Check the fuses under the hood again - especially the one named "ST SIGN" - if its ok it might be a wiring problem.
Also it wouldnt hurt to have the battery tested - starter requires huge amount of current (like 300 amps) - if your battery is on its way out - it may not operate the starter properly - but other electrical devices may still be fine.
94 Mx-3 Precidia
