Nice vid, How are your guys' coolant temp readings? mine seem to be around ~15 degrees warmer then ambient on coldstarts, and my engine temp peaks out at a little over 200.
What are you guys getting?
megasquirt / gm sensor question
- XxantwawnxX
Mine is usually right near ambiant and alwasy goes to 215 on the dot , never more..never less.
Not how it comes stock. That was part of the deal, the MS I send you has been modified for 3 extra outputs (fan, vris, whatever) and has had the modifications made for ignition control. It was the same ecu I made 395 whp on. No way in hell I could do that without ignition control. It has a full 12x12 ignition map.oh-hell wrote:ALSO,,, will the v2.2 controll timing?
I gave you the software in that floppy disc. you MUST use that to tune the car, unless you want to switch to a different firmware and software version. I already loaded the corresponding MSQ and firmware into the ecu to run with that software to save you time.
Here is the megasquirt'n'spark site. read more. megasquirt.sourceforge.net/extra
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
Now thats a hook up. Props to Rebel, i tortured him and he never failed to give me in depth answers to my questions , shipped lightning fast, sent links and done everything he could to be helpful!! thanks dude !!
[fs] 92 MX3 gs 2.5 klze v6, Intake, Exhaust,drop zone spring{awsome},Turbo, Splitfire plugs, fmu, gauges ,drilled slotted rotors ,motegi rims,tires,Blackout lights, and a nut behind the wheel~~ so far.
No problem at all, I think youll be very happy with the setup once its all in and runningoh-hell wrote:Now thats a hook up. Props to Rebel, i tortured him and he never failed to give me in depth answers to my questions , shipped lightning fast, sent links and done everything he could to be helpful!! thanks dude !!
And you didnt bother me.... too much. Haha
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
