HELP! Installed ZX2's, Got Rear Rubbing! Now What?
solo_ryder
Post by solo_ryder »
It may have something to do with the type of strut then, I had no problems with my tokikos and my 215-35-18's
precidian
Post by precidian »
II was running 215/35s on an 18x8" rim with a 38mm offset. When I had the stock suspension in, I had no issue with rubbing at all. When I put in new struts, the rim actually rubbed the strut. I put in simple 5mm spacers to take care of that issue.
Turned out that the location of the strut bolt holes were slightly different then the stock struts.
Tom S. - '94 MX-3 GS-X Sparkle Green
I say, Ahmed. What is that thing you do when you're about to assassinate an infidel?
