hey guys thanks for the info. This is great keep it comming.
GChristian, i like the door panels, they look very good. I defantly want fabric tho...keeps my arm cozy haha...
ovendenk, i can't wati to see your door panels man..i saw your seats, they look fricken sweet.
Taras: You out there man? If you are, ask the guy who did yours what glue he used..they look amazing. Ask him how he did it tooo.
Perhaps sticky this?
Door Pannel Recovering
- monty73741
Jason Danaher
Please Help Support MX-3.com
- ovendenk
hey, just got one of mine done today. i also did my headliner with black suede.
![Image](http://ca.geocities.com/ovendenk/pics/Seats/door_insert.jpg)
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
![Image](http://ca.geocities.com/ovendenk/pics/Other/sig.jpg)
- ovendenk
thanks. to be honest, it's not tremendously difficult, but you have to take your time with it. took me almost 2 hours for this panel because i didn't wanna screw it up. i used 3m hi-strength 90 spray adhesive.Vanished wrote:Ovendenk thats fricken sweet. But the real question is:
How did you do it? Please explaine...
quick how to if you wanna call it that. make sure to use a towel or something to press down the material with to help apply even pressure.
1. mask off door panel to protect from overspray
2. light coat of adhesive on panel and back of material to prep the surfaces.
3. start near the middle by spraying some adhesive and putting down the material.
4. make sure your material will cover the entire panel and if not, lift and replace the material until you have proper starting placement.
5. work outwards by spraying adhesive and forcing material into the grooves. the adhesive has a bit of play time where you can quickly lift the material and replace it if you get wrinkles or something. just do a bit at a time, trying to glue the whole thing in one shot can only spell disaster.
6. once you are done, go around edges, lift material, spray a little adhesive, and try and get the material to go down into the groove..
7.i got some piping to press into the outer crack to help clean the edges up. it just gets glued in the crack with super glue.
btw, i used a clean white rag and varsol to clean any glue that seeped through the material. the rag absorbs the glue and the varsol will evaporate.
thanks perry and taras for everything.
- Jettblackcat
- ovendenk
thanks a lot. hopefully my interior will be done soon.Jettblackcat wrote:Hey, kick-a$$ job.... Question: did you peel off the old crap first, or just lay the new over top?
put it over the old stuff. having a material like that gives great adhesion for long life, but i can slightly feel the old material when i rub the new stuff. i dunno. i'm 90% satisfied with the outcome. still got the driver's door and rear panels to do. we'll see how they go.
