My Car burns ALOT of oil.... WHAT SHOULD I USE?
MazdaManiacMx3
ikarus1 I would like to disagree with you in using a diesel type oil , only because the fact they have more detergents in them , eating seals much faster in a gasoline engine and over time making the problem worse.
If your engine is currently that bad (2 quarts every tank) Then I would reccomend using a higher viscocity high milage oil. Maybe 15w40- or 20w40 This will help in the means in which it is thicker so much less will pass through . You may have a small loss of power (heavier oil equals more friction -the good kind) But you will see parasitic loss from the fact that the motor has to work harder to churn the oil.
If you are getting a new engine anyways , this is the only way I can see you saving some money because in terms you will have to buy less oil because it burns less.
As for you guys wanting KLDE engines , I may be getting my hands on some in a short while and may be looking to get rid of them quite cheap , but I will keep you updated on that ..
Kris
Kris
93 Kandy Tangerine Mx3 GS-DE
05 Saab 9-2x (Wrx power plant)
02 Subaru Impreza OBS
05 Subaru forester Xt - sti mods
04 dodge ram - toy hauler -FOR SALE
& Lots of Toys to haul
