1.6 SOHC ... performance questions...
maddog8664
- Shady469
It should be a SOHC.
(BuGs hope you dont mind)
What: The exhaust ports on the SOHC head are alot bigger than those on the B6T head. But IIRC the intake ports are the same size if not a bit smaller. It's really kind of strange. But to those thinking of doing big things with the SOHC have faith! A good port and polish, cam, and a different intake manifold (along with boost of course) should produce some good numbers. If i could start all over (and not have dumped so much money into different motors/set-ups) i would boost the SOHC just because.
Hell, if i can find a Festiva for cheap its getting a boosted SOHC... well maybe not but i can dream!
(BuGs hope you dont mind)What: The exhaust ports on the SOHC head are alot bigger than those on the B6T head. But IIRC the intake ports are the same size if not a bit smaller. It's really kind of strange. But to those thinking of doing big things with the SOHC have faith! A good port and polish, cam, and a different intake manifold (along with boost of course) should produce some good numbers. If i could start all over (and not have dumped so much money into different motors/set-ups) i would boost the SOHC just because.
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
