Whats Your Top Speed In The MX
- XxantwawnxX
125 stock. 137 ZE
- papa roached
i been to 130 and scarred the hell out of me
- freyguy_412
hgallegos915
90 mph gs..somethings wrong i gave up on finding out what it was..im driving the hell out of it tio get a klde. or ze.
-hec
140kph with stock K8 i didnt wanna go faster.
Ever notice anyone driving slower than you is an idiot and anyone driving faster than you is a maniac?
01-03 Civic Projector Swap Tutorial
120 mph like 3 or 4 times. I wasnt exactly sober at the time (but I wasnt drinking, dont worry) so I dont know what the problem was, either speed cut or misfiring. It would climb to 120 then stop, felt like a stumbling. This was at 7 psi of boost on a KLDE. I'm running a KL48 ecu. It must have a speed limiter built in?
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
My old K8 seemed to have stopped accelerating at just under 190km/h. I've hit just over 200km/h once. First I just wanted to say i hit the 200km/h mark, and 2, i didn't want to have my personal fastest speed with my old k8...I accelerated to 200km/h and coasted back down to resonable speeds right after my needle broke the 200km/h mark. You move past alot of road at 200km/h...
150+
I WAS RACING A CAMARO AND I JUST KEPT GOING ON THE PEDAL I BOUNCED OFF 150 TWICE.IT WENT FROM 140 TO 150 AND BACK TWICE I WILL NEVER DO THAT AGAIN. MAYBE
IGOT A KLDE SWAP IN A MX-3 WITH THE PROBE TRANNY WITH A CURVED NECK MANIFOLD
forcedairram
No clue
Honestly ive only hit 95... just got the car last night... its got the bp and pro lx tranny swap. I really havnt got to get it on a good straight stretch seing as it has no tags on it. but I have already managed to get the cops looking for me.
http://www.cardomain.com/ride/1404826
BROKE DOWN POS
BROKE DOWN POS
osargeant
Unfortunately for me I have the JSpec MX3 which has a speed limit governor of 180km so the car fuel cuts just after that number. I have hit that number tons of times since I turboed the car.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
forcedairram
speed
only got to 120mph going uphill with the windows down...the car felt like it was gonna lift off the ground. tried it with the windows up and it felt like a different car.
BROKE DOWN POS
BROKE DOWN POS
