to succesfully lower your car
Re: to succesfully lower your car
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by thebonestockkid:<BR><STRONG><P><BR>Is this true?? well damn it all, looks like its not gonna be as easy of an install as i thought... or is it easy? i really dont want tires with no tread on one part and decent tread on the rest lol. If its too difficult/expensive i think i migh have to sell the intrax's :S. good to know tho.</STRONG><HR></BLOCKQUOTE><P>Camber bolts are actually easier to use than using OEM size bolts. The tricky part comes in adjusting them correctly. I'm sorry I don't know how much camber adjust you'll need, but I had to move mine almost 3 degrees when I used the zx2 struts. Get high grade metric bolts & lock nuts, at least grade 10. You'll probably need 4 bolts. You'll also need an alignment afterward.<P>If you don't make the camber adjustments, not only will you have uneven trad wear, you'll also have VERY quick tread wear, and slightly worse gas milage.<P>Good luck
tk1138<P>There's not really anything I want to say over and over.
- Buff1110
go grade 8. extremely strong. <BR>Dan
Dan
02 Tacoma TRD - Daily
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Sonicxtacy02:<BR><STRONG>I'll be venturing on this too in a few weeks. I'll be using stock struts with eibach pro springs (thanks hank
</STRONG><HR></BLOCKQUOTE><P><BR>i'd give a hand if i had a clue what i was doing.
I just changed my spring today. All I used was 14mm, 17mm and 19mm sockets and spanners and 2 manual spring compressors. Jack up the car undo the shock bottom then top, pull it out change the springs pop back in. Best done with someone else and takes about 45 minutes a shock
'92 MX3 1.8 V6
G-MAX 40mm lowering springs
'91 AZ3 1.5 35mm drop +V6 stryt brace.
