The name of the guy on ebay is "japanese_performance_engines" The guys actual name is moe. They are located in ontario I believe and the shipping was $100 US..
You can look at the motors he has at this address
The mx is FINISHED!
- Franko
Re: The mx is FINISHED!
could you give us a list of the cost's of things like the engine and intstall, ect?
- Franko
engine was like 1200, gearbox was about 500, the cv axels were 100, apexi safc 2 was 400, all the piping for the intercooler was a suprising 160ish, the intercooler was 150 and I had to change the end tanks so that was only like 75. Ohh and a blow off valve that was about 200, then there were mounts and some other stuff like gauges and all that.. but I would say it was a few thousand to buy everything.. and the install was 1000 even.. so I did allright with it.
- papa roached
no thats a BPT
