Re: larger injectors setup
Posted: November 28th, 2002, 5:28 pm
I looked at it but it´s quite expensive, and import taxes and charges will eat many of my funds. I´d like to investigate with the two speed fuel pump mod, which I have found to my surprise that it exists and is used on many cars! I have found a lot of info about this, including wiring diagrams (Toyota users bypass their relays to achieve maximum fuel pump flow at full time) While I was printing all those articles a nasty idea come to my mind while thinking on how I could have a lean idle, and here´s my latst and crazy idea:<BR>It´s to create a calibrated air leak after the VAF with a filter attached to it and controlled by a solenoid,which will be operated by a vacuum dependant switch (Vacuostat) which will be connected where the pcv vent valve was before having it´s own little filter (boost into the valve cover produces the oil stick to take off!!). It sounds scary!!
<p>[ November 28, 2002: Message edited by: BATTOSAI ]
