![Surprised :eek:](./images/smilies/icon_surprised.gif)
larger injectors setup
Re: larger injectors setup
I looked at it but it´s quite expensive, and import taxes and charges will eat many of my funds. I´d like to investigate with the two speed fuel pump mod, which I have found to my surprise that it exists and is used on many cars! I have found a lot of info about this, including wiring diagrams (Toyota users bypass their relays to achieve maximum fuel pump flow at full time) While I was printing all those articles a nasty idea come to my mind while thinking on how I could have a lean idle, and here´s my latst and crazy idea:<BR>It´s to create a calibrated air leak after the VAF with a filter attached to it and controlled by a solenoid,which will be operated by a vacuum dependant switch (Vacuostat) which will be connected where the pcv vent valve was before having it´s own little filter (boost into the valve cover produces the oil stick to take off!!). It sounds scary!!
<p>[ November 28, 2002: Message edited by: BATTOSAI ]
European Mx3 GsRT
Yes you are crazy and enjoy making things more complicated than they have to be.
<P>Buy a MAP sensor, either 2 BAR or 3 BAR. This is the proper way of using the S-AFC. I don't have the link with me right now as I am at work but do a search on Yahoo for "fooling the S-AFC", the site is based on info for the integra but it works just the same.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
