Page 2 of 2
Re: KD8 ECU/VAF TO KLZE
Posted: September 23rd, 2004, 10:07 am
by Absath
Is it a straight plug swap? The ECU I've got here was cut out of a car, wiring harness and all, so I wasn't sure if the wiring harness was different for the KL36. If it's something I could do myself, I would probably give it a shot.
I've gotta bring the car in anyway to get the SS clutch line installed, to try and solve the problem with my new ACT clutch. I figured I would do it all at once.
-Tim
Posted: September 23rd, 2004, 10:34 am
by Sean Mandell
u do not need to change the whole wiring harness!!!!!just unclip the old one and throw in the
new one....easy...
If you are putting a ss clutch line in you might as
well change ur brakelines to ss as well...
Posted: September 23rd, 2004, 12:21 pm
by Absath
Ok, how do I access the ECU then? Where is it located? Should I unplug the battery before swapping them out?
-Tim
Posted: September 23rd, 2004, 12:31 pm
by ZEmadman
yes unplug the battery! im pretty sure it's behind the center console...but i cant confirm that, my chiltons manual says yes, but my chilton manual also covers the millenia, 323, and 626.
Posted: September 23rd, 2004, 12:42 pm
by lakersfan1
There are side panels to the back of the center console next to the gas pedal. Take the trim panel clips out, pop panel, the ECU is right there. I believe it's only held down by a couple trim bolts.
Posted: September 23rd, 2004, 1:26 pm
by papa roached
un plug the bat, pop those panels, unplug it, unbolt it, swap the brackets over and bolt the KL-36 in then plug it all back in and your good to go
Posted: September 23rd, 2004, 1:29 pm
by Absath
Cool. I'll give it a whirl this weekend.
-Tim
Posted: September 23rd, 2004, 6:22 pm
by mdavis
Originally posted by mdavis:
Originally posted by papa roached:
Originally posted by Si:
I run a K8 ecu & KLDE vaf - runs well
i agree, same as i run
Originally posted by Nd4SpdSe:
I run a ZE ECU with K8 VAF, runs great
What is the difference between these configurations?
( KLZE ECU + K8 VAF // K8 ECU + KLZE VAF )
My bad, I meant
( KLZE ECU + K8 VAF // K8 ECU + ___KLDE___ VAF )
<small>[ September 23, 2004, 05:25 PM: Message edited by: mdavis ]</small>
