Page 2 of 2
Re: Pasesetter Short Shifter...
Posted: August 18th, 2003, 8:03 pm
by Tyler17rose
Any pics of how short it really is? I cant wait for mine! I'll probably put it in tomorow.
Posted: August 18th, 2003, 10:55 pm
by honeybabes
Hey Tyler....Is that $100 including tax? On stock or have to re-order? I might get one aswell from Goldwing but have to pay what i owed from a friend first.
Posted: August 19th, 2003, 2:06 am
by Tyler17rose
100 plus tax, but i got a deal. its 115 regualar.
Posted: August 22nd, 2003, 1:23 am
by Tyler17rose
Shifter is in now. Its awsome tiny throws, nice and short, good quality. But a few questions and comments. Is everyone else's pacesetter sorta notchy? Mine is very notchy shifting from first to second. The rest of the gears a silky smooth. Is there a way i can fix it? please tell. Oh and since the shifter is shorter now and not bent as much my arm sorta has to stretch alot. Might be because my seat is all the way back cause i'm tall. But its sorta annoying reaching like i have to.
Posted: August 22nd, 2003, 1:32 am
by JasonH
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by T-Rose:
Is everyone else's pacesetter sorta notchy? Mine is very notchy shifting from first to second. The rest of the gears a silky smooth. Is there a way i can fix it? please tell. Oh and since the shifter is shorter now and not bent as much my arm sorta has to stretch alot. Might be because my seat is all the way back cause i'm tall. But its sorta annoying reaching like i have to.<hr></blockquote><p>I bent my Pacesetter using a vise and some lengths of pipe. I managed to bend the part where the knob attaches back about an inch.<p>I don't know about the notchiness. I think what you're feeling is the lack of "slop" that your stock shifter (with worn bushings) had. Make sur the pivot is all greased up and that your attachment bolt isn't too tight. Does the 1-2 shift feel different than the rest even if the car's not running/moving?
Posted: August 22nd, 2003, 1:39 am
by Tyler17rose
I'll try bending it, but maybe after awhile of use. I dont want to break it before i even get to use it :D . And it seems to be getting smoother the more i use it. Maybe it just has to get worked in a bit or something. Next time i get a chance i will check the bolt underneath and lube it up some more. Other then those 2 things this thing ROCKS i love the tiny throws!
Posted: August 22nd, 2003, 9:36 am
by RedSallad
So your saying if i ordered the Pacesetter Short Shifter or as they call it "Quick Shifter" off of corksport i would get the bushings along with it.
Posted: August 22nd, 2003, 11:42 am
by JasonH
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by RedSallad:
So your saying if i ordered the Pacesetter Short Shifter or as they call it "Quick Shifter" off of corksport i would get the bushings along with it.<hr></blockquote>
Yes.
Posted: August 23rd, 2003, 2:53 am
by jamario
Check out this Pacesetter short shifter for $69.99 and free shipping at http://store.dragracing.com/product.asp?prodid=1099&catid=15&jump=1#apps. If that doesn't work try looking for it at dragracing.com
Posted: August 23rd, 2003, 8:41 am
by Gro Harlem
If you have side to side play in your shifter, it probably isnt' your shifter...its probably your linkage arm. <p>I looked at mine and the two bushings on the other end of it were totally gone causing about 3" of side to side play inside the car. Now i need a new shifter arm b/c the bushings on that pivot point aren't removeable :(
Posted: August 23rd, 2003, 11:56 am
by JasonH
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Gro Harlem:
If you have side to side play in your shifter, it probably isnt' your shifter...its probably your linkage arm. <p>I looked at mine and the two bushings on the other end of it were totally gone causing about 3" of side to side play inside the car. Now i need a new shifter arm b/c the bushings on that pivot point aren't removeable :( <hr></blockquote>
Are you sure they're not removable? The SRD bronzoil bushings are a set of four, 2 for the shifter, and two for the other end of the shifter arm.
Posted: August 24th, 2003, 12:02 am
by Tyler17rose
I'm thinking about ordering Lucs bushings. I know a guy that made them fit in his pacesetter shifter. Hopefully that will help smooth the shifting out a bit.
Posted: August 24th, 2003, 12:58 pm
by mx3TT
When I first put mine in the shifts were a little hard. After a while it got lighter and easier to shift. Give it a little while.
