KLZE curved neck manifold VACUUM hookups. Please help!
Re: KLZE curved neck manifold VACUUM hookups. Please help!
Gro currently I have the same MS8 Vacuum hook up issue as u. Do u have any pictures of your engine bay and where you hooked everything up?
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
- papa roached
not all US spec are like that, i got one from a 97 Millenia, dont have a castingOriginally posted by babyblueMX3:
normally the millenia US mani and ze are the same except the ze has a casting line mark on top (round shape) of the manifold..so yeah gro has the ms8
Gro Harlem
KK this is the way i hooked mine up, and what i found out in my research.Originally posted by Talon_66:
Looking at my picture above...there are 5 nipples, but there is a 6th on the #6 cylinder runner that i didn't circle.
1: is the brake booster hookup for RIGHT HAND DRIVE cars. For LEFT HANd drive cars, this was used for the ABS hookup. On my manifold, it is plugged
2: This is for both VRIS solenoids. Hook it up like the stock manifold is hooked up (a t-fitting coming from both solenoids going through the two vac chambers and a checkvalve
3: Used for brake booster on LEFT HAND DRIVE cars. ABS module on RHD cars only. I used it for my brake booster.
4: used for the PCV valve on valve cover. I looped my hose around to fit it properly.
5: Used for purge control. Since the millenia manifold doens't have a hookup for cruise control, I just T-fitted this with both the purge and my cruise control.
6 (not circled): on #6 runner. is for the fuel pressure regulator solenoid.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
this should be in FAQ or something, i'm sure everyone who swaps manifolds on KLZEs would enjoy having this around =) I'm doing the swap in a couple of weeks and I know this will help me with the vac lines
1992 MX-3 GS
KLZE - Fidanza Flywheel - CM IIR Clutch - Millenia IM - UR Pulley - IM Spacers - KL36 ECU
- papa roached
i will be doing one here in a few months, i would love to have this around, save for it only covers the pre 95 intakes, i have a post 95 and its a bit different
Gro Harlem
Take a pic of post-95 manifold!! WHen I did my research, i found more about those than the pre 95's, so I'd be able to help label those too.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- babyblueMX3
you don't have a casting mark and that what i said you don't have a casting mark...only ze curve neck (ms8) does..never saw saw a domestic millenia manifold with this casting line on topOriginally posted by papa roached:
RIP 400whp ZE-T MX-3
