So I saw a GS driving around recently, and I thought "Heh, some teen riced out his hatch with a wing, good thing mine looked stock", but then the car felt kind of familiar and I was like "Wait a minute", so I came to check this thread, and I was like "Oh..."
Gotta say it, the wing aesthetics bug me. Was never a fan of it. It is the only square shape on the entire car. Mazda's styling lines are curvy, smooth, and flow organically, but then you arrive at the boxy shape at the end, and it clashes. It's probably the designer in me being nit-picky, but whenever I saw those wings on MX-3 they always felt like they were from the wrong car, I'd prefer a wing that follows the curve of the lip, instead of being a rectangle. And it's tarnished further by being on top of the lip, which gives it that over-stacked double-decker one-wing-is-not-enough look, common among certain ricers. I think you know the wings I'm talking about. Does it actually serve any function other than styling?
But honestly, the wing would probably be the only thing I'd chuckle at if I saw it on a car. Everything else looks pretty decent and tasteful, and you're mostly just adding little touches, so good for you for keeping a stock-ish appearance. It's so rare to see a proper clean MX-3 that's traditional and hasn't been molested with silly "styling mods".
Are your new headlights any good for visibility and beam pattern? I liked the projectors because they offered good visibility while having a controlled, focused beam, without bleeding into the eyes of oncoming traffic (as a courtesy to other drivers), which is why I went with projectors instead of HID conversion.
On a separate note, one thing about dropping it too low and part of the reason I kept it close to stock ride height is I've had issues with axle bind (in the CV joint) during hard cornering when it was too low. I had to go through quite a few axles before I found one short enough to avoid binding at the height I had it. I don't know if you had that happen, hope not, but just something to keep in mind.
Other than that, keep it up. I'm gonna go back to fixing my RX-7, maybe I'll come to another Mazda meet sometime, when I figure the damn thing out.
