MX3.com quarter mile time list
JWMotorsports
Re: MX3.com quarter mile time list
I got a nasty itch to take my car to Diwiddie, VA on a Friday night before the end of this season and roast a 1/4 one time before they kick me off the track...I bet I can trap 130+MPH on a open diff....last trip to 1/8th mile resulted in bye bye axles and MS-LSD clutch pack exploded. Cars been sitting since son was born last December.
I'm surprised I don't see more 13sec or faster times!
I gotta get a new clutch so I can do a 1/4 mile run
upping to 20 psi soon, getting slowly in the 12:P
96 rs-t mx-3, 12.62@114
u have the Zoom Zoom feeling?
JWMotorsports
kab-rst...what turbo are you planning on turning up to 20psi?
i'll keep my small t3 and try what it can takes(about same size as the vj-23) so i'm hoping 18 to 20 psi
this winter, i'll swap gt28 ou gt30 i'M not sure right now, i have to keep in mind that it's a daily drive before being a drag beast
QUARTER MILE TIME LIST update
Nickname -- Engine Type -- ET -- MPH --
TITOMX3 ------------ KL-01 Turbo ----- 11,080 -- 129.00mph
Limegreen mx-3 ---- BPDE Turbo------- 12,400 -- 118,00mph
Slammed6 ---------- KLZE Nitro -------- 12,600 -- 108.00mph
therieldeal ---------- BPT GTR ---------- 12,611 -- 111.27mph
hppwdn ------------- KLZE Turbo ------- 12,958 -- 114.97mph
XxantwawnxX------- KLZE Turbo ------ 13.300 -- 110.00mph
93MX3KLZE-T ------ KLZE Turbo ------- 13,400 -- 108.00mph
kab-rst -------------- BPT GTX --------- 13.476 -- 106.70mph new time
cjthor --------------- B6DE Turbo ------ 13.700 -- 108.00 mph
Stereoking15 ------ KLZE N/A --------- 14,084 -- ???.??mph
slinkymx3 ---------- ZE/DE Turbo ----- 14,200 -- 100.40mph
andy ---------------- K8 Turbo --------- 14,300 -- 105.00mph
comish71 ----------- KLZE N/A -------- 14,320 -- 95.90mph
timpronk ------------ KLZE N/A -------- 14,385 -- 98.21mph
mx3autozam ------- KLZE N/A --------- 14,400 -- 99.70mph
Mooneggs ---------- KLZE N/A --------- 14,545 -- 95.69mph new time
Nd4SpdSe ---------- KLZE N/A --------- 14,756 -- 91.51mph
93MX3KLZE-T ------ KLZE N/A --------- 14,800 -- 93.00mph
Brennan ------------ KLZE N/A --------- 15,200 -- 94.00mph
JWMX3 ------------- KLDE N/A -------- 15.453 -- 91.89mph
OutlaW ------------- K8 N/A ----------- 15.567 -- 84.60mph
96mx-3 ------------- K8 N/A ----------- 16.100 -- 84.40mph
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
thebonestockkid
May as well throw my ancient old time somewhere in there... it's in my sig.
'97 Grenada black pearl Acura EL, JDM B18C 98spec ITR Swap. Power in Control full coilovers going in next spring. Not to mention a most unusual whining noise... coming soon.'92 Intense blue pearl Jeep YJ, OME lift, mudders, fun.
R.I.P.
'93 Clear white GS-DE ~14.648@92.98mph, 2.234 60ft. PARTING OUT PM ME.
projectzemx3
- mx-3_4evr
I'm going to try to break into the high 13s with my all motor BP
Stereoking15 -------- KLZE N/A --------- 14,084 -- ???.??mph
mx3autozam -------- KLZE N/A --------- 14,400 -- 99.70mph
thebonestockkid ----- KLDE N/A --------- 14.648 -- 92.98mph new time
- hppwdn
OutlaW wrote:QUARTER MILE TIME LIST update
Nickname -- Engine Type -- ET -- MPH --hppwdn ------------- KLZE Turbo ------- 12,958 -- 114.97mph
Actually, that run was with a KLDE turbo. I probably need to update my sig. The ZE went boom awhile back.
hppwdn ------------- KLDE Turbo ------- 12,958 -- 114.97mph engine code edit
i'm 6th!!!!!!!!!!!!!!!!!!!
http://s106.photobucket.com/albums/m279 ... 13_078.flv" onclick="window.open(this.href);return false;
kab's time
12 run with drag radial, 7 on 15'' M/T slick
drag radial best
13.377@104.90
60' 2.06
slick best times
13.078@104.90
60'1.857
i'm so proud i'M actually celebrating tonight, so close of hissing the 12, but i ....arhem... ran out of gaz
kab's time
drag radial best
13.377@104.90
60' 2.06
slick best times
13.078@104.90
60'1.857
osargeant
Congrats kab-rst,
Nice to see the 4cycl turbo MX3s representing.
I am assuming this is still with the VJ-20 turbo that comes with the BPT engine? How much psi are you running? Also are you running race gas?
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
check the worklog section, i did 13.7 on my stock bpt with the vj20@15psi
this summer i swapped manifold,t3 turbo,and wastegate,now boostin14 psi
i want to be in the 12' before upping the boost
