I shall be fitting the B6 with a 323 manifold & VJ Turbo,Good work love to see your progress. when are you going to swap out that stock B6 or are you planning on tweaking it with like matching cams and such.
SPEC/centreforce clutch, AEM F/IC & boomslang harness,
larger injectors, FMIC with smaller width radiator and 2" - 2.5"
alu boost pipes, and possibly a larger bore exhaust down the line.
