Mi|<e - 94 GS BPT dyno tuned
Re: Mi|<e - 94 RS BPT
HAhA ya whassup i got tein springs
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
Those are Eibach Pro Kit lowering springs on KYB struts.
I did the rear brakes too so I don't have to revisit any rear work for quite some
time after this:
time after this:
1994 MX-3 RS
Worklog: viewtopic.php?f=46&t=62251
B6 goodies for sale:
viewtopic.php?f=2&t=66333
2nd BP engine: http://www.clubprotege.com/forum/showthread.php?t=46695
Ive finally obtained the hardest piece to find for the project, a 28 spline kia
halfshaft.
Now I can put the new transaxle, clutch, balljoints, front suspension and axles on
the car leaving me with the finish line in sight.
halfshaft.
1994 MX-3 RS
1994 MX-3 RS
So after trying to find information about the G series transmission, I came to the conclusion that there
is alot of info on how to dis/re assemble them. There isn't alot of info on how to reassemble the case. So
lets reassemble my case.
First thing to do is clean the mating surfaces and apply a nice thin layer of high temp silicon:
Make sure the top of the reverse gear is pointing to the outside:
Your case had better have the tranny fluid 'transfer piece / black thing ' already bolted on before you
drop it down:
Find the shift rods, they like to wobble so pinch them together while you drop the case down from above:
Once the case is on these bolts are extemely important to get in before fiddling with anything:
(You may have to pull up on the longer shift rod sticking out of the top of the case to get
this to line up right)
The only other side note is make sure those copper washers are on there! The rest
is fairly self explained:
And finally the reverse light sensor:
drop it down:
1994 MX-3 RS
Heres a picto-how-to for the 5th gear:
First pic is cleaning off old gasket material with a plastic scraper (guitar pick)
so the aluminum isnt damaged. Its soft stuff.
32mm and 27mm sockets for the stake nuts up top.
1994 MX-3 RS
Today I did a bunch of subframe painting and removed the old balljoints
from my hubs.
I also refurbed the RX-7 injectors:
from my hubs.
1994 MX-3 RS
Old F series throw out bearing:
New G series throw out bearing:
Filled motor mounts:
My subframe is black, not rust color:
1994 MX-3 RS
AndersonR
amazing job, man !!!
I got the flywheel back today, replaced the rear main while the tranny was off:
Machined flywheel:
And spec clutch:
I used blue loctite so my nuts wouldn't fall off
stopped short today because I injured my hand. Might get the tranny on
and front end assembled tomorrow.
Machined flywheel:
And spec clutch:
1994 MX-3 RS
Damn what a journey. I'm a V6 MX-3 guy but that's a fine 4CYL you done up there. Well done.
1995 Eunos 30x KLZE
- drewhall07
looking good man. ill be doin the v6 to bp05/turbo swap soon. pickin up my 92 gs 2mrrw. can wait to start on it.
Tranny is in, new suspension up front, new balljoints and tie rod ends.
And you can see those nice thick kia axles:
1994 MX-3 RS
Very meticulous, very detailed, very skilled in my eyes. Keep up the amazing work and preserve another one of these amazing machines!
man i remember when this project first started, car looks awesome. great work your doing bro
