So I had a bit of an emergency last week when my tire started peeling on me!
 I know, scary stuff.
There are a few reasons why this happened.
First of all you know my Enkei rims? The Yokohama tires that are on them were there when I first bought the rims off a guy about a year ago, and even then he suggested that I should get new ones, however I wanted to get more life out of them so I did. Second, I had a wheel bearing incident in the fall that you can read about
here. Ever since then I took out the camber bolt on that side because I replaced the whole spindle, so I've had negative camber there since the fall (and that's the side that started peeling). Also when I did the swap and had to take out the axles I took out the camber bolt on the other side so that side's had negative camber for just over a month.
So why didn't I get an alignment? I've been waiting to put on new suspension components first so that I don't have to do it twice, this was supposed to be my "winter maintenance" but I never got around to it. I've got new tie rod ends, new LBJs and new wheel bearings to put on. Also I've had some "new" tires sitting around for a few weeks but didn't throw them on for the same reason - I don't want to until I got an alignment so that I don't prematurely wear them out.
They are Hercules G5000Z, ultra high performance summer tires
 I bought them with the rims but they are going on my Enkeis and I'll be selling those rims, even though they're decent. Plus the tires are 215/40/17 so I'm finally upgrading from my 205/40s, these will be closer to stock size and fill the fender a bit nicer
But anyways because of the peeling tire I had to address this immediately, haha. Well turns out when my wheel bearing went in the fall, the circlip broke off the groove in the spindle where it sits so that whole spindle/knuckle is now garbage. So I'm still stuck using a 92 spindle on one side with a smaller LBJ. Looks like the new wheel bearings and a LBJ will have to wait for another time when I get some spindles. But I still need an alignment ASAP so I decided I'm gonna throw on what I can. Put on the new tie rod ends and I'll be getting alignment tomorrow morning. It's gonna be funny driving around with 2 different rims haha! Only for a bit though, cause after alignment I'll be going to get the tires put on.
