What oil weight is recommended from the Mazda?
How many qts to fill?
Thank you
Absolutely right. Still, on the other hand, if they werent sufficiently thick for lubrication, they wouldnt recommend them either. They arent in the business of rebuilding and replacing engines under warranty that spun bearings for lack of lubrication. Oil doesnt need to be as thick as many think it does, especially synthetics.They recommend thin oils to help meet CAFE standards.
Actually it is, in dino oils the higher the spread the more polymers are needed to give the base oil its multi-viscosity properties. They break down and form more deposits than a lower spread number would for that very reason.its not any different of a blend than 10w30, all conventional oils are going to break down burn and have deposits, its what they do. thats the whole reason to change your oil every 3K miles.
Synthetics will lubricate better because they dont shear on the molecular level nearly as much as regular dino oils, they are more stable, and the ingredients that form sludge just arent there, so the engine stays 'cleaner'. A synthetic will lubricate at a much higher temperature and at a much thinner viscosity better than a thicker dino oil will in the same situation.and synthetics seem to be alot thinner in comparrison to conventional oils in the same weight. but thats the whole point w/ synthetic, lubrication.
High mileage oils contain special conditioners to keep seals from drying out, some have 'friction modifiers' (probably zinc...I'm guessing, it may be something else) added, more detergents, and more additives to keep it at its intended viscosity. 10w30 "high mileage" oil isnt any thicker than regular 10w30 oil. It doesnt thin out as fast, but its not thicker to being with.also on a motor with over 100K miles on it, it would probably be a good idea to run 10w40 just for the fact its thicker. cause as the engine wears, oil clearences get a little bigger than when they were new.
Quite frankly, to make the oil companies more money. The world got by the last 80 years without it just fine. If you start out with the proper viscosity oil to begin with and change it at the proper intervals you really dont need it.what do you think the whole point of the high milege oils are for.
Yes, thats true. In most cases though they are wrong and they know it. Your friend got a lawyer, and they gave in. GM has a history of that kind of thing. Back in the '80's, when computers were becoming the big new thing on cars, Cadillac had their system set up such that the dealer could read the computer when the vehicle came in for repairs. The computer was programed to log any time that the car went over 65 mph during the first 1000 miles, and the dealers/GM were using that info to void the warranty. Their excuse was "Hey, the manual says don't go over 65 mph until the engine is broken in." They got sued. They lost.As far as voiding warranty, be carefull with that. My friend had a Saturn that he was trying to do a lemon law return on...and Saturn was refusing to allow it because he had...used 10w30 oil instead of 5w30, which was what the manual said to use. Its wasnt until after he got an attorney that they allowed it. So they WILL give grief over it...
