94 mazda mx3 - 1.6L, 5speed - driver side axle problem
The driver side axle is "stuck" on the inside connection. My local mechanical spent a couple of hours trying to uninstall the axle to no avail. Any ideas?
Re: 94 mazda mx3 - 1.6L, 5speed - driver side axle problem
Hi!
So, there's a spring clip that sits on the axle that holds it inside the transmission (part #1 in the manual link below). There are many methods that people say get these things out.
http://www.mx-3.com/manuals/showimg.php ... _M-028.gif
Here's a few thread from the forum on the issue. They should give you some ideas.
http://mx-3.com/phpBB3/viewtopic.php?f= ... it=circlip
Wings on an MX3? What are you thinking?
92 RS BP05
93 GS KLZE
(Previously owned by 2Fazed and then mrMazda92)
92 RS BP05
93 GS KLZE
There is an axle puller you can probably rent it. I used one and the axles just popped out.
- mitmaks
I used giant wheel/tire iron and wedged it between axle and transmission and pulled on it, axle popped right out.
I love it when you talk dirtymitmaks wrote:I used giant wheel/tire iron and wedged it between axle and transmission and pulled on it, axle popped right out.
