Kakarot135's 93 MX-3 rs
Thefez
Re: Kakarot135's 93 MX-3 rs
Post by Thefez »
you wouldn't happen to wana sell me thos center caps would u?>
kakarot135
Post by kakarot135 »
They are my only set so I cannot part with them. Ill keep you in mind if I find another set in good condition.
Kakarot 135
kakarot135
Found a guy selling a '91 escort gt, car has a stock motor in it and a spare motor as well. Waiting for pictures to make sure they are both bp engines and will most likely by them if they are. Looks like a good start to 2014. Will update when I get them home.
He sent a few pictures.ImageImageImageImage
Kakarot 135
kakarot135
What do you guys think worth 500 without a title.
Kakarot 135
Sleeper6
Post by Sleeper6 »
kakarot135 wrote:What do you guys think worth 500 without a title.
I wouldnt pay over 300 for something without a title, at that point its only scrap value.
RobMinhas
Post by RobMinhas »
Those are for sure Bps.
Buy it, try to get a deal if possible but don't get hung up assuming the engine is good. BP swap is a good upgrade to your SOHC.
MX_Sid
Post by MX_Sid »
That's a pretty fair deal as long as there are enough usable parts between the 2 motors for a solid build. Depending on your budget, I would look into used import engine yards. Picked up my BP for around $300USD and it was tested for compression and had a limited warranty.
Unfortunately it didn't have alt, throttle body, etc. just a bare engine. So if you're already planning a rebuild, go for it! Seems like a fun Frankenstein project :freak:
But look them over, inside crankcase, etc. and keep your fingers crossed there isn't internal damage, ie; thrown rod, warped head, cracked block...... those could take the fun right out :crying:
GOOD LUCK!! Hope this helped
I HATE mechanic shops and LOVE junkyards!!
kakarot135
The mx3 is tucked away for winter with my new-ish toy.
Time for some delayed maintenence.
Teaching the next generation about cars.
Valve cover off, new distributor on.
Good thing I got new plugs ans wires too.
More to come, still looking for my motor, then the real fun comes.
On the plus side this is the first time in 4 years without a check engine light for the camshaft positioning sensor.
Kakarot 135
