I am looking for an in-tank fuel pump rubber mount. I lost mine when I disassembled it to clean he tank.
Or maybe direct me to where I can buy one.
THANKS!!!
[WTB] Fuel pump rubber mount.
- kudkudniyog
Re: [WTB] Fuel pump rubber mount.
Not sure if you need the fuel tank rubber seal (gasket) or the rubber mount that goes under the pump. Both are available at rockauto. The rubber mount that goes under the pump is included with some of the pumps. For example a $16 pump includes this rubber mount. You are probably fine without the rubber mount if you zip tie the pump to the metal bracket instead. The fuel tank gasket, a rubber seal, is sold separately.
- kudkudniyog
Thanks for the info. I just purchased a walbro pump with install kit. The kit comes with the rubber mount at the bottom of the tank.
