Thanks man I really appreciate your help. So its okay to run the car while I'm this low on coolant? I suppose it will be fairly cold long enough to fill it.SuperK wrote:fill it up by the filler cap next to #8 on the second link.
The filler cap is the cap on the passenger side, the radiator cap is on the drivers side.
Here are some directions from wytbishop that has a pretty clear explanation of some steps:
With the engine running, but COLD, remove the top filler cap on the passenger's side of the engine and fill right to the top. Now leave it off and carefully remove the rad cap. This will allow any air in the radiator to escape. Replace the rad cap when it gets to the top and then fill the engine right to the top again. Make sure the overflow res is filled to the bottom line and your cooling system will be totally full
Overheated on highway ==> Thermostat?
Re: Overheated on highway ==> Thermostat?
93 Blaze Red GS
Followed wytbishops steps and everything is looking good. Thanks everyone again.
93 Blaze Red GS
Or you could have a blown head gasket. Just sayin,,, ![Shrug :shrug:](./images/smilies/shrug.gif)
Yeah, I mean I lost all my coolant for a reason so I'm keeping an eye on the level and for leaks.Daninski wrote:Or you could have a blown head gasket. Just sayin,,,
93 Blaze Red GS
Coolant just doesn't disappear. Maybe it's been slowly leaking out and you just didn't notice.
- [LVPA]93GsSe
I'm with dan, have you checked the tailpipe for white smoke and a smell of caramel?
Knowing you've spent too much on your car,
yet, you still want to keep modding. -priceless
boosted_bullet
93 Honda Accord LX - Wrecked
95 Honda Del Sol Si - Stolen
92 Honda Accord EX - Parted out
2000 Toyota Celica GTS - Cracked block and broken differential teeth
93 SE - ATX to MTX, work as always in progress
01 Toyota Celica GTS - DD
Worklog to be up soon, still... ...
boosted_bullet
