Using A Power Steering Pump To Supply A Remote Mount Turbo
posey92
Post by posey92 »
Simple as that. Saw a quad turbo 454 that used a power steering pump to pull and push oil to the 4 turbos...so instead of using an expensive $300+ oil pump to pump oil to the turbo and and back...its already good for the hi heat and volume to move...its mechanical so less likly to fail and its alot cheaper to do that...if ur doing a ps delete its already there.....
RogueWolf
Re: Using A Power Steering Pump To Supply A Remote Mount Tur
Post by RogueWolf »
I'm not sure if that blurs the line between Genius and Crazy...
posey92
Post by posey92 »
Im leaning towards genius.later I'll look into it more and post more info.got a turbo and stuff last night
posey92
Post by posey92 »
So ill be doing this soon. I have a turbo and gauges I'll be remote mounting
The turbo where the cat is.then using a closed oilsystem itll go ps pump to turbo to an oil cooler thru the pump and do on.
zerialz
Post by zerialz »
This is some mad scientist s--- right here.
posey92
Post by posey92 »
It will be when I'm done...
Return to “Forced Induction”
