25 Fuel pressure regulator control solenoid
So thats one of my codes...though it was my regulator but guess this is one of the two plugs on top of the intake and facing the front the right connector is broken off...so could this be why im burning gas...and I cant find any at the jy is there any way yo wire it in a bypass it or do I have to order one.
Re: 25 Fuel pressure regulator control solenoid
Anything guys tired of wasting fuel
you need to get a solenoid. K801-18-740.
Just to make sure I know what you're talking about, the FPR solenoid should have a vacuum hose that comes off the fuel rail (off the FPR) and goes into the black solenoid which is connected to the wiring harness. then there should be a 2nd vacuum line out of the solenoid to the side of the intake manifold. This is what you're looking at, correct?
Yup thats it...any other cars have this or is this k8 only...
