please help
- inthemaking
please help
car quit today car was running vary well pulled over made a call to the wife then pulled out and car stalled like it had no gas bit there was gas there and gas to the injectors now just turns over engin is klze
1992 mx-3 with kl-ze costum paint and interior performance white 17" rims and now a new audio fiberglass setup
1993 mx-3 rs parting out
Re: please help
got spark?
Re: please help
Id start there too. Once you verify that you don't have spark, pull the cap off the distributor and make sure it is actually moving when the motor is cranked. If it is moving, the timing belt is good. If it isn't moving, timing belt is broken.Sleeper6 wrote:got spark?
1993 Mazda Mx-3 GS-Sold
1992 GS "The Bucket" Gone.
92 GS 5spd for sale! Sold it....after I got a hatch cover in great condition
MY WORKLOG, check it out viewtopic.php?f=46&t=79959
- mx3_ryder
Re: please help
It would be easier to just look through the oil filler cap to see if cams are rotating to verify timing belt assuming you have someone to crank over the engine.atx_mx3 wrote:Id start there too. Once you verify that you don't have spark, pull the cap off the distributor and make sure it is actually moving when the motor is cranked. If it is moving, the timing belt is good. If it isn't moving, timing belt is broken.Sleeper6 wrote:got spark?
- inthemaking
Re: please help
I was just working on it and yes I got no spark timing belt rotates how you know that it's a distributor check cap rotor
Re: please help
Please do this. viewtopic.php?f=23&t=69006
Good news is your disty is a commonly found part at the wreckers. Ford Probes, MX-6 and 626 have your disty last number can be 1 or 2. Happy picking or refer to my link.
- inthemaking
Re: please help
what's a dusty
Re: please help
Distributor.
- inthemaking
Re: please help
I will look in to it thanked for your help
- AaronTietje
Re: please help
Agree, It's most likely a distributor.
- inthemaking
Re: please help
picking one up on sat let you guys know how it goes
- inthemaking
Re: please help
what the #@&@! I put another disty in today it's alive got sparkyeah but timings out i tried to set it but no luck
its back fireing stalling hard to start just running like a peace of #&$! dont know if its a sensor like crank or tbs please help
Re: please help
Did you jumper TEN and Gnd in the diagnostics box before trying to set the timing?
- inthemaking
Re: please help
no I kind of forgery how to do timing
- inthemaking
Re: please help
will that help for the back fireiing stalling and hard starting
