FS: Seized K8 for rebuild or parts
ProjekMX3
Post by ProjekMX3 »
My engine seized due to lack of oil last week thursday. It was consuming oil but there weren't any of the telltale signs of oil consumption. Anyway I'm selling my k8 because I need money for the ze swap. I'd like to sell the engine as a whole but if there is enough demand I will part it out. The engine has 109K on it when it died. I'm not sure how much this is worth so just make an offer. Any contribution you can make to the ZE fund would be greatly appreciated. Email me at n3street@wmich.edu. AIM: Projekmx3
92 GS, 210 psi per cylinder KL-101 Engine, Pacesetter Exhaust, Centerforce DF, CAI, Hi Flow Cat, Headers.
By Spring 06: Megasquirt and FPR
By Fall 06: KL-31 Heads with Interprep Cams
mrspanky79
Re: FS: Seized K8 for rebuild or parts
Post by mrspanky79 »
worth nothing
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
endocyc
Post by endocyc »
Spankys right, you have scrap metal on your hands
ProjekMX3
Post by ProjekMX3 »
O well looks like i'm gonna have to get a second job. It was worth a try thanks everyone for your help. The mx3 will return stronger and faster.
Tempus
Post by Tempus »
Block itself is hosed...
Save the other parts since you might need some of them (distributor etc) to do a swap.. but once it's done you'll have some spare stuff you can sell off..
{sigh} Time to move on
Out with the old: Tropical Emerald MX-3 GSR (KL-DE)
In with the new: Phantom Blue Mazda3s GT
papa roached
Post by papa roached »
save the back power steering pump bracket too, i needed mine from my K8
lakersfan1
Post by lakersfan1 »
If you want to ditch the engine, see if Western has an auto center. I know when I was at Central, they had a auto shop and some of the students did tear down and rebuilds on broken engines.
