lagging under power/ back fire?
- mazdaspeed23
Re: lagging under power/ back fire?
how do you confrim if all the lights on the dash are hooked up to the ecu? on the right side you have oil,seatbelt, etc. on the left side i have no lights that come on at all
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
![Image](http://i1187.photobucket.com/albums/z397/moneyshot23/rsz_1994155_10152926217650640_511810948_n_zps966fe00a.jpg)
My MX-3 is nothing without me, and i am nothing without my MX-3
2007 Ford Fusion SE
Ok, so your idle should be at 700 then adjust your timing. Not sure where the timing would sit at 1000 rpm maybe someone can check their car if they have a moment. The disty from the MX6 is the same as the one listed for the 03 MX3 and that's true up to around 96 on the MX6.
Tons of different ways to wire up a HEI? There's only two ways, in which the 93-4 have two wires on the 3 pin plug wired a certain way, then 95 has those two wires swapped over.
You also don't have to hack the wires, many people have no clue that you can actually remove each wire from it's connector plug by carefully prying off the orange plate in front, then once that's off you have two hook type bits of plastic that hold each wire in. You get some small tweezers and pry those open whilst pulling on the wire and it will come out.
1995 Eunos 30x KLZE
- mazdaspeed23
is there a FAQ or a step by step on how to do it for a 94 ze?
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
10 points for using the word 'whilst' in proper contextRX8SE3P wrote: whilst pulling on the wire
94 is 94. There are no ze de k8 differences, all that matters is the year of your car, which would dictate the year of your wiring loom. I used one of the diagrams by that nd4spd fellow. It's a very clear diagram.mazdaspeed23 wrote:is there a FAQ or a step by step on how to do it for a 94 ze?
1995 Eunos 30x KLZE
- mazdaspeed23
Can a bad disty cause back firing? http://youtu.be/a0tKWLxfocc
back fire is crazy, its not only doing it with WOT now, its doing it as soon as the car starts.
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
- mx3_ryder
I always noticed my car sounded like a Subaru when the distributor was misfiring...mazdaspeed23 wrote:Can a bad disty cause back firing? http://youtu.be/a0tKWLxfocc
Never seemed to backfire, but also never held at "WOT".
Have you pulled a lead while car is idling to see if you have good spark?
You're looking for a steady blue spark... Its that simple.
If you've got good spark then start look'in elsewhere. Could be fuel related.
- mazdaspeed23
It never started untill I cleaned the disty. Maybe ill start there. Replace it if it doesnt work then ill go on to the next thing. It used to happen with WOT but now its doing it no matter what
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
Do you still have a catalytic converter on this car? The bogging down under acceleration and backfiring are symptoms of an exhaust restriction.
There is a difference between backfiring and misfiring. If I understand this post there is backfire and loss of power under load and it is getting worse. My guess is that it is getting worse because the exhaust restriction is getting worse. If the catalytic converter is coming apart inside it can create more exhaust restriction over time.
If this is misfire then ignore me and carry on with disty replacement.
![Image](http://imageshack.us/a/img407/384/50r4.jpg)
- mazdaspeed23
its a back fire. it sounds like someone is shooting a gun from th muffler. like pop pop pow. also just did fuel pressure test and its good.
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
Just replace the disty or do the HEI mod. If you look at the schematics you'll figure it out I'm sure. You've had so many disty related problems I think the HEI mod is way past due. Cheers ![Very Happy :D](./images/smilies/icon_biggrin.gif)
- mazdaspeed23
lmao i hear ya there. this is the 4th disty
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
- mazdaspeed23
yes i do have a cat on the car. I also did a compression test tonight, fuel pressure test, line test, hold test, FPR test. an they all turned out normal.
is our disties the 1.8 Liters and w/.526" Diameter Rotor Cam? im buying a new one, and everyone keeps asking me for different diameter rotor cams? im not sure what one is the right one
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
- mazdaspeed23
well guys got some good/bad news. Good news is i got a new disty $400 took the problem away, however its the wrong disty, car wont time correctly and takes forever to start, its off by 20 degrees for timing. So return time, this time i will try a disty for a 94 mx-6 2.5l hope this works. Wish me luck
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
