Splash covers under the engine
[LVPA]93GsSe
Post by [LVPA]93GsSe »
Does anyone know if the protege has the same covers or even a probe maybe?
Knowing you've spent too much on your car,
yet, you still want to keep modding. -priceless
boosted_bullet
93 Honda Accord LX - Wrecked
95 Honda Del Sol Si - Stolen
92 Honda Accord EX - Parted out
2000 Toyota Celica GTS - Cracked block and broken differential teeth
93 SE - ATX to MTX, work as always in progress
01 Toyota Celica GTS - DD
Worklog to be up soon, still... ...
kulluminati777
Re: Splash covers under the engine
Post by kulluminati777 »
no and no but maybe you could rig something up so they fit
[LVPA]93GsSe
Damn. was hoping it would work but thanks for the info. I'll look in to it and post up if I find anything
boosted_bullet
[LVPA]93GsSe
@kulluminati777
I tried the shields off a late 90s pritete and the fdrivers side fit withe just a small slit in the plastic. The passengers side wasn't a very good fit tho, the wheel well fits but the front doesn't much but some pulling and some zip ties I got it on til I can figutr out something more solid.
boosted_bullet
RobMinhas
Post by RobMinhas »
I like what Fowljesse did, he chopped up one of those bigass bristol boards for campaign signs and cut holes and bolted it to the bottom.
kulluminati777
[LVPA]93GsSe wrote:@kulluminati777
That is cool.
RobMinhas wrote:I like what Fowljesse did, he chopped up one of those bigass bristol boards for campaign signs and cut holes and bolted it to the bottom.
I want to do the same thing but i never see any huge campaign signs around town. I definitely wanted to do his idea because of the traction bar I have. With his idea i can have the bar AND keep the bottom of my engine protected from water
[LVPA]93GsSe
Nice. I got a big box from work and I'm gonna cut out a mold for under the bumper and maybe the splash shield and cover up the bottom of the bumper and part of the engine and trans hopefully. I will then wrap it up to water proof it, and eventually make it of something more durable. I got the idea from autospeed.com.
http://www.autospeed.com/cms/article.html?&A=2159
http://www.autospeed.com/cms/A_2160/article.html
http://www.autospeed.com/cms/A_2162/article.html
I even went and bought a vacuum gauge to test it as he did in this article but my mx hasn't been running to try.
boosted_bullet
[LVPA]93GsSe
boosted_bullet
