No start with air flow meter plugged in
[LVPA]93GsSe
Post by [LVPA]93GsSe »
I have been trying to figure out why my gs will start with the meter not plugged in but not with it plugged in. I recently did the hei and coil mods and replaced the meter. I double checked all the wiring, I'm kinda stumped right now. :cry:
Knowing you've spent too much on your car,
yet, you still want to keep modding. -priceless
boosted_bullet
93 Honda Accord LX - Wrecked
95 Honda Del Sol Si - Stolen
92 Honda Accord EX - Parted out
2000 Toyota Celica GTS - Cracked block and broken differential teeth
93 SE - ATX to MTX, work as always in progress
01 Toyota Celica GTS - DD
Worklog to be up soon, still... ...
Thefez
Re: No start with air flow meter plugged in
Post by Thefez »
did you check the basic's so far spark fuel air? I mean I know you said you did the HEI Mod but did u check to see if you deffinitly have spark?
[LVPA]93GsSe
Yup i have fuel and spark. But i don't have spark if I plug the meter in.
On a side note could I get the side panels for the hatch, the part the lid pivots on?
boosted_bullet
[LVPA]93GsSe
I've been lookin through the wiring diagrams and the throttle position sensor and engine temp sensor are connected to the meter, but Idk if they would cause it to not start with the vaf plugged in
boosted_bullet
[LVPA]93GsSe
Solved. Thanks thefez, Pm'd ya.
boosted_bullet
zayd687
Post by zayd687 »
what was it?
[LVPA]93GsSe
My connector was loose and I replaced the connector from a KL and mixed up the wires when I did, I miss read the diagrams. :oops:
boosted_bullet
