hey guys, need some help.
my reverse lights stopped working today and not sure why, I checked the bulbs and they seem fine, checked fuses and they are fine. im going to assum the wiring is fine because they were working with no problem then out of the blue they just stopped working. not only that im at my bros house and he doesn't have a volt meter or test light. so im just going to assume they work. is there a back up switch somewhere, or a relay? day time lights work, signal lights work, brake lights work. just no reverse lights
REVERSE LIGHTS NOT WORKING
- mazdaspeed23
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
![Image](http://i1187.photobucket.com/albums/z397/moneyshot23/rsz_1994155_10152926217650640_511810948_n_zps966fe00a.jpg)
My MX-3 is nothing without me, and i am nothing without my MX-3
2007 Ford Fusion SE
- [LVPA]93GsSe
Re: REVERSE LIGHTS NOT WORKING
I would double check the connector.
Knowing you've spent too much on your car,
yet, you still want to keep modding. -priceless
boosted_bullet
93 Honda Accord LX - Wrecked
95 Honda Del Sol Si - Stolen
92 Honda Accord EX - Parted out
2000 Toyota Celica GTS - Cracked block and broken differential teeth
93 SE - ATX to MTX, work as always in progress
01 Toyota Celica GTS - DD
Worklog to be up soon, still... ...
boosted_bullet
- kulluminati777
theres a back up switch on the tranny i believe
"11" on this diagram http://www.mx-3.com/manuals/photo.php?f ... J2-012.gif
Same place on the F series manual trans too.
Wings on an MX3? What are you thinking?
92 RS BP05
93 GS KLZE
(Previously owned by 2Fazed and then mrMazda92)
92 RS BP05
93 GS KLZE
- mazdaspeed23
I will go out and check, it could have corrosion on it
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
- mazdaspeed23
Thanks guys, checked the connector and cleaned it up and works again
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
- [LVPA]93GsSe
Good to hear, glad to help!
boosted_bullet
boosted_bullet
