Trailing arm
WhiteFinish
Trailing arm
Post by WhiteFinish »
Damn those things !!
After 22 years, those things won't come loose.
With a lot of force the bolt started moving. Had to use a big wrench with extension to unbolt it.
And of course.... at the very last moment, the part on the other side of the bolt decided to come loose, so the bolt spins together with the other side.
Who has some tips how to get this thing out ??
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
Inodoro Pereyra
Re: Trailing arm
Post by Inodoro Pereyra »
Hmmm... I guess getting a wrench on the other side is not an option, and a grinder is also impossible, isn't it?
I'd say, how about a hacksaw blade, and a helluva lot of patience? :shrug:
Diogenes of Sinope.
fowljesse
Re: Trailing arm
Post by fowljesse »
Why don't you put a wrench on both sides? If there's not enough room, you may have to grind a wrench to make it skinny. I don't remember how I did mine, but it seemed easy.
Re: Trailing arm
Post by wytbishop »
You have to break the cage that holds the nut im the back side and move it aside so you can get a wrench on it. It's not easy. I used a hammer and a long cold chisel.
ganue
Re: Trailing arm
Post by ganue »
I just got done - literally an hour ago doing the exact same thing - except on midwest rusty crusty - not like your shiny new looking assembly. At least you made me feel good that you (spoiled) folks in non-rust belt areas have to deal with the same issue.
Wyt's right. Remove the cage. I used a sawzall and cut only through the structure to the rear of the bolt/nut. This exposes the SQUARE nut. Bend the cage out of the way and latch on with a great pair of vice grips. Not easy and be patient but you can grab on well enough and after about 20 full turns of popping the vice grips off incessantly, you'll have the bolt free.
Re-installation is probably controversial. I reuse the bolt, get a nice grade washer and hex nut and you are good to go. Drove like this for 10,000+ miles with no issue.
1993 GS SE - "slow" (Stock) - SOLD
1993 GS SE - "fast" (Curved neck KLZE, OBX headers, custom 2.5" exhaust, KL36 ECU, Exedy Probe GT clutch, KL36 LSD - the real one, Lantis Type R lefthand halfshaft - unfortunately worth mentioning)- SOLD
1993 GS SE - acquired 4/28/2013, SOLD February 28, 2015
1985 RX-7 GSL-SE - SOLD
2003 VW GTI 1.8T
2009 Mazda5 Grand Touring
WhiteFinish
Re: Trailing arm
Thanks for the tips people !
I'll give it a go this weekend.
**although I'm not surprised it's so stuck, the car is from '91**
Worklog click
Re: Trailing arm
Post by wytbishop »
When I did my suspension a couple years ago I managed to get one off OK but the driver side bolt had to be cut.
I was able to get in there with an angle grinder and a 4" zip disk and cut the nut end. Its no good cutting the bolt head off as you won't be able to get the bolt out the other side since the body will be in the way.
WhiteFinish
Re: Trailing arm
It worked, cut the sides and held the bolt on the other side.
Damn what a crazy thing !
Worklog click
ganue
Re: Trailing arm
Post by ganue »
Yay! The forums come through again!!!
2003 VW GTI 1.8T
