[WTB] KL Starter, 36-1 pulley
Looking for an Item you'd like to buy? Post here.
This section is NOT for selling.
Ryan
Post by Ryan »
36-1 crank pulley
MTX K8/KL starter
I may add some other stuff as I think of it. Prefer one seller. Shipping to R0A 0V0 Manitoba Canada
Ryan
MrMazda92
Re: [WTB] KL ECU, front pads, etc
Post by MrMazda92 »
I have a KL47 ECU sitting on a shelf... I want to say Millenia ECU, right?
If you'd be okay with the VRIS points being off, shouldn't be too bad.
2fazed
Post by 2fazed »
I have either a Kl55 or Kl57 if interested.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
Ryan
Post by Ryan »
Either of you have spare front pads, or LBJ's?
MrMazda92
Post by MrMazda92 »
I have 2 lower ball joints, but one has a boot that is toast... The other has maybe 5,000 miles of travel on it, and has a grease fitting attached.
I'm only getting rid of it because I need to swap to the 94+ 18mm shank style ball joints for my current project.
I do not have extra pads at the moment, unfortunately.
2fazed
Post by 2fazed »
I might, but I don't know if their gs or rs pads
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
Ryan
Post by Ryan »
doesn't matter IIRC, fronts are the same.
Ryan
Post by Ryan »
Bump, added starter.
crazycanadian
Post by crazycanadian »
I have a KL01 ecu.. and KL88((I think- its stock mx3 1.8 V6).. also have the matching JE50 VAF...
Return to “MX-3 Related Want to Buy Forum”
