High oil temps
WhiteFinish
High oil temps
Post by WhiteFinish »
Hi Guys,
There is a fellow Mx-3 driver on the Dutch forum who asked me to get some US advise ;)
I got a problem with my oil Temp.
I just installed a KLDE in a mx3 and everything is workin fine, exept for one thing.
My Oil Temp gets to 130 degrees celcius (266 fahrenheit) when im just drivin sportive not even track style.
The water Temp stays at 90 celcius (194 fahrenheit) and the cooling fan kicks in like it should be.
I checkt the piston rings by takin out the dipstik while running to see if the exhaustgas blows out there and theres nothing.
So i asume that the piston rings are fine.
What could this be ?
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
SuperK
Re: High oil temps
Post by SuperK »
The top piston ring can expose oil to 160 °C (320 F)
I don't think the test he performed is necessarily accurate, I'd say that more testing to determine the condition of hte piston rings would be necessary. the dipstick goes pretty low into the oil pan. I would think that most of the excess pressure would be blown through the crankcase.
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
My GS Worklog Thread
RobMinhas
Re: High oil temps
Post by RobMinhas »
Is he certain his oil temp gauge is accurate?
Ryan
Re: High oil temps
Post by Ryan »
I'd also cross check the gauge.
My oil temps can exceed 250F, but only if cruising over 4000 RPM on a hot day, or racing on a track longer than a minute or two. I also have an oil cooler delete.
Also, loads in the cylinders at idle are minimal. A 'quick' check on the rings is to do a WOT 2nd gear pull and full engine brake with someone following him looking for any significant smoke.
bbunkerc397
Re: High oil temps
Post by bbunkerc397 »
I have also found that the ebay headers that loop around under the oil pan causes excessive heat in my oil temperatures. I think the oil is breaking down i was going to add an oil cooler to see if it would help. Also a oil pressure sensor would help as well and probably a really good quality oil temp sensor.
1996 MX-3 KL-ZE with Eunos 800 IM, factory side skirts,. "Owner since 2001 my 14th year"
1992 929s 20B-REW Lowered, 17" chrome Millenia rims, custom black interior. "13th Owner 9th year"
2006 Chevy HHR LT "Bought Brand New - East Side Chevy" Sold to my Dad
Ryan
Re: High oil temps
Post by Ryan »
They should all loop around, thats how they maintain equal secondary lengths for better torque characteristics. What you can do if you're concerned, is wrap the exhaust around the pan area. I did that :)
bbunkerc397
Re: High oil temps
I was thinking of doing that as well but I thought the pacesetter headers looked better designed, they don't loop back under the oil pan and the bolts are easier to get at.
Ryan
Re: High oil temps
Post by Ryan »
Unequal length headers will make it sound gnarly, and you change the torque compliment due to secondary scavanging. Check out the KL SAE papers, it briefly mentions the effects of secondary length.
