Anti-Drop Shifter Bracket for 5-speed cars
New product ideas and status of new product development postings.
kulluminati777
Re: Anti-Drop Shifter Bracket for 5-speed cars
Post by kulluminati777 »
havent had mine drop at all but i wouldnt mind one....just in case
You guys should probably email him as he hasn't logged on since September of last year... :roll:
kulluminati777
hahahahah maybe ill do that
Post by wytbishop »
Weistal67 wrote:Reviving an old thread here but hoping you still have some/are still making them. Let me know. had the shifter drop on me and tired of jamming it back up.
Aaron
It's actually easier to go to Pick n Pull and repalce it than to install that anti-drop bracket. You can use the stabilizer from either a GS or an RS or a 90-94' protege. The stabilizer rod is the same, the only differences are in the shift change rod so just put your shift change rod into any of those stabilizer rods and you're good.
MrMazda92
Post by MrMazda92 »
I still need to snag both linkages for my '93, thanks for the reminder!
Post by Josh »
my GS has one, I hate it. It has a high pitch squeak that drives me crazy. I have to pull it apart and find out why.
MrMazda92
Post by MrMazda92 »
My '93 does as well, there's slight vertical play with the bracket installed. As for the shifter linkage itself, I slipped with the drill when I was modifying the 3rd link... Oversized hole and some excess play due to that.
Jforce
Post by Jforce »
Are these still available?
RobMinhas
Post by RobMinhas »
As of July 2012 no they were no longer available for the MX-3.
Evo_Spec
Post by Evo_Spec »
these are easy enough to make though, just grab some flat metal bars from home depot or whatever, cut 2 pieces, bend them and put some epoxy and stick them together and drill a hole
Damn, I have the guys name who made a batch. $28 bucks. I'll see if I can dig up his Email.
My question is why can't we just clean up the rubber, buy a two part rubber mix like Flexane 94, glop some on and reinstall the damn shifter. http://www.devcon.com/products/products ... 4%20Liquid or http://www.freemansupply.com/DevconFlexane94Fle.htm
A 1lb can will fix your shifter and fill all your engine mounts as well. :2thumbsup:
Evo_Spec
Post by Evo_Spec »
Daninski wrote:My question is why can't we just clean up the rubber, buy a two part rubber mix like Flexane 94, glop some on and reinstall the damn shifter.
that's kind of what i did, i just did it WAYYYY more ghetto lol
Personally I hate silicone. I think it's the most over rated crap on the market. I highly recommend finding a good two part rubber system however a lot of people have commented on using JB weld to repair stuff like engine mounts. I've just never heard any comments 6 months later to hear if it's holding up ok.
Jforce
Post by Jforce »
I still have some polyutherane, its shore A60 in hardness.
Would that work?
Just pour it between the shifter housing and the bracket? Like on Evo_Spec's image.
And i'm not actually sure if it actually dropped.
There's about half an inch of space between the bar and the bracket. Is it supposed to be tight against it?
The car shifts ok, but i've got a scratching/ringling noise coming from somewhere over there (only under acceleration and high speed, not at idle or revving in neutral so its hard to locate, I'll post a video of the noise later Edit: http://www.youtube.com/watch?v=_twTNrki ... e=youtu.be). The bar is touching de exhaust. And also the endlink (shifter Gearbox side) is a little loose i guess.
This one is slightly loose:
Gro Harlem
Post by Gro Harlem »
wow, didn't think this thread would still get replies. I'm updating the first post w/the pictures Chris took & the price/payment info.
I'm not sure if he still makes them but I do know he uses that email address so email him if you need this bracket.
DONATE TO MX-3.COM
Return to “New Product Development”
