[WTB] Interior Items
- MrMazda92
Re: [WTB] Interior Items
I'm with Moon... I don't recognize that bar, and I've tried to pull the lower seatbelt mounts from a few 94+ models, with no luck.. All rusty, which is no longer a problem, since I now have a blast cabinet.
any pics yet Mooneggs?
1995 Ford Escort- No its not an MX3, but it has lots of MX3 parts on it.
Modifications: too many to list, see the first page of my worklog.
http://www.clubprotege.com/forum/showth ... X-work-log
Sorry forgot to update. I went to the junkyard and the 94 was actually a 93/94 hybrid so it didn't have the manual belts. However I saw an older 323 that had something similar. Is this how the setup is that you have? If so then I have never seen that before in an mx-3.
I have a similar thing in my 93' MX-3. It's basically exactly the same, but black.
Thanks for the pics. Yes my setup is exactly the same and black as well. My stuff came from a Canadian Escort.
Wyt, does your car have a cover over the area I have in the pic on the first post or is yours like the pic above?
as an update I took some pics of the setup in Josh's 94 US Spec GS. Note he is missing the plastic cover over the bolt in the floor.
- mazdaspeed23
hey i dont have the cover for the bolt that holds the seatbelt on the side, but i have both covers that cover the bolt that hold the seat into the floor bord
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
My MX-3 is nothing without me, and i am nothing without my MX-3
2007 Ford Fusion SE
