93 1.8 died no start- stumper
bshalla
Post by bshalla »
so i have spark and on time while cranking, fuel pressure 40psi while cranking between the two rails, no air restriction. it did die as if it were running out of fuel. i checked all sensors and relays that have to do with the injectors, all tested within spec. im lead to believe ecu is at fault unless someone convinces me otherwise. Thanks for your input
SuperK
Re: 93 1.8 died no start- stumper
Post by SuperK »
the air flow meter may be faulty, or timing may have jumped. I would doublecheck timing is correct then your air flow meter.
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
My GS Worklog Thread
bshalla
Post by bshalla »
timing is 7-9 degrees advance while its cranking, tested maf as per service manual and tested within limits.
SuperK
Post by SuperK »
you can try removing the air flow meter from the intake hose and see what happens when you crank it. it'll pull unmetered air and should rev uncontrollably and you can just turn the key and shut it off. sometimes it'll get stuck closed and wont' allow proper airflow.
there's a 100 people selling k8 ecu's for super cheap as well if you wanna go that route. I'm one of the people included in the "trying to sell their ecu" group
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
bshalla
Post by bshalla »
well im not seeing any other route i tried the meter on and off and it moves by hand freely
Sleeper6
Post by Sleeper6 »
checked compression?
Ryan
Post by Ryan »
It juts cranks normally, as if it were not getting spark or fuel?
Do the injectors actually fire? remove the distributor, turn the key to "ON" and turn the disty by hand. listen for their ticking in time with you rotating it.
bshalla
Post by bshalla »
What should the compression be? If i turn dist by hand the injectors should pulse is what your saying?
Ryan
Post by Ryan »
Anything over 80 and the motor should run... but 140 minimum, 140-170 is standard, 180 is excellent.
and yes, thats what I'm saying. Its an easy way to make sure its working. The only difference turning it by hand is the starter isn't turning, so you can actually hear whats going on. As far as the electronics are concerned, its the same.
bshalla
Post by bshalla »
if i dont hear anything that would mean cam sensor? there also is no codes
bshalla
Post by bshalla »
well i could here them hiss but the strange thing is that i had them unplugged from when i tested for voltage?
bshalla
Post by bshalla »
so if i have injection, how i can make sure its on time. I even pulled distributor apart to make sure everything is lined up and tride and different cam sensor and the same time
bshalla
Post by bshalla »
..still looking for more possible causes if anyone knows anything
Ryan
Post by Ryan »
the hiss is the fuel pump running, this means your NE1 signal (the 6 tooth hall effect) is working. This means your injector and ignition timing is correct.
Do you hear the injectors ticking? If you don't, the problem may still be with the G signal, the hall effect that tells the ECM where cyl 1 TDC is. Without this, it won't know where it is in the 4 stroke cycle, so will never send the first ignition event.
Basically, you need to verify that you have spark. Remove a plug wire, hold it near a ground, and watch for the spark when someone cranks it. If you have spark, you have fuel.
mitmaks
Post by mitmaks »
Check for broken timing belt
