Im interested to know just how low I have gone with my coilovers..
.. Is there anyone out there with fully standard ride height who would
measure from the ground upto the inside lip of the arch/fender in the centre of the wheel
back and front for me?
Thanks in advance
Anyone with standard ride height wanna measure?
- MrMazda92
Re: Anyone with standard ride height wanna measure?
Might add that this is RS height, judging from your Signature
Ah yes thats right, thanks. Not realised there was a difference!
- MrMazda92
I'm not sure the exact difference(measurement-wise), but the springs are different to make up for the difference in weight. It shouldn't be too terribly far off, either way.
- kakarot135
On my rs, stock suspension with 15" honey combs, and 195/60 15's it is 25 1/2 inches in the front, and 25 3/8 in the rear, from the center of the hub to the lip is 14 1/4 front and 14 1/2 in the rear, wheel and tire size should not affect that.
Hope this helps
Hope this helps
Kakarot 135
Thanks thats great. So by my measurements that makes mine - 3 1/2" (90mm)
