Best I can do is; Our Father who art in heaven hollowed be thy name, thy kingdom come thy will be done on earth as it is in heaven,,,,,,,,,,,,,,,,,,,,,,,,,etc
If you were able to plug an OBD1 ECU into your OBD2 harness I can understand things going titers. If you replaced all the bad wires one for one you should be ok. Stupid question but is the clutch switch connected?
need advice please help !!
Re: need advice please help !!
yup but like i said the parts i got it was from 02 of 96 wich is the same as mine, but the one i pulled off says B6GDB in small letters and mine says B6GD remanufactured i dont know if that had anything to do with the problem . it was from a manual car and so is mine.. all the pins match my old one and so does the harness but the ecm grounding part i dont know what you mean hopefully that is the problem why i have no fire..
yes that clutch switch wire was fried aswell i changed the switch and the wire i triple chequed all the wires nothing is melted together its all good now.. damm i hate electrical stuff grrrr
