I commented on your comment then realized I'd deleted the pics hence the egg on my face. Was that too complicated for you?carizle wrote:Daninski wrote:
Well who has egg on their faceNeed to reinsert the pics.
Engine Swap
Re: Engine Swap
- carizle
Re: Engine Swap
No buddy I got it before you did, hence my first smart a$$ comment on the pics not being there. Would you like another egg sir?Daninski wrote:I commented on your comment then realized I'd deleted the pics hence the egg on my face. Was that too complicated for you?carizle wrote:Daninski wrote:
![Pimp :pimp:](./images/smilies/pimp.gif)
If it weren't for physics and law enforcement, I'd be unstoppable!
98 Mustang Gt-convertible, bolt-ons and SCT race tune-Cams and 4.10 gears coming soon
SOLD-92 GS beater-280,000 miles and still goin strong-HEI mod
SOLD-91 Explorer XLT 4x4-never let me down, at least when I can afford to fill it up
Re: Engine Swap
Any ideas where those plugs might go? Or are they extra accersories?
Re: Engine Swap
- Lower left, grey plug, is your anti knock (goes to anti knock sensor under your intake manifold) you may need to reroute the wire from the other side of your motor, have a look.
- Top left, grey plug, power steering pump
- Top middle plug, black, is your rear O2 sensor plug (the plug and wire should be pushed down behind your VRIS)
- Finally; top left plug, grey, should plug in on the firewall about 3" (15cm) below where it is now but I can't remember what it's for. Follow the vacuum line from your TB and that should lead you too the solenoid where it plugs in.
Re: Engine Swap
You obviously have no idea how to help this member so take your brainless comments and book it sunshine.carizle wrote: No buddy I got it before you did, hence my first smart a$$ comment on the pics not being there. Would you like another egg sir?
Re: Engine Swap
I looked for those plugs still cannot find where they go the only one i found was for the manifold???
Re: Engine Swap
Ok, on the exhaust manifold at the back of the engine is an O2 sensor with wires to a black 4 pin plug. That plug may be hanging down behind your engine. You may need to go under the car to get to it.
The knock sensor wire, grey end will probably be near your distributor and you'll have to route it over to the other side.
