Here is an excellent link to help anyone diagnose fuel problems. This could possibly go into the FAX section. http://www.airtexproducts.com/AIRTEXpdf ... TTS_09.pdf
Bit more info on Walbro replacement pumps. http://www.autoperformanceengineering.c ... _kits.html
Fuel Delivery System Diagnostics
Re: Fuel Delivery System Diagnostics
Very helpful link indeed!!!
klze swap, wisco 8.5 comp pistons, pauter rods, act stage 3 clutch, lightened flywheel, UR racing pulley, flex-o-lite oil cooler, 2.5" custom exhaust with high flow cat, B&M short throw shifter, S&R cross drilled rotors, , B&G lowering springs, maxxim 17" gun metal rims, modded nissan injectors, walbro 255 lph fuel pump, areomotive afpr, msd 6a , magasquirt v3, and turboed
