car wont start and hold light flashes
Newfie_dan
Re: car wont start and hold light flashes
Post by Newfie_dan »
the smp one runs $58 not to sure why they want to charge so much for a relay, hell I can probably get a good one from the local junkyard for and ship it to you depending on your location.
jokerless06
Post by jokerless06 »
that relay doesnt look like the one i took out the one i took out the prongs look like this
but i oedered one i found one that was 25 bucks the code on it is b577 ans also i have another question the spark plugs that r there in the front of the motor theres three rite there in the front rite k the one on pass side has oil in it can that keep it from firing is that the #1 firing r whatever and that is the dealership price for this relay
Newfie_dan
the oil in the plug hole is a result of a leaking gasket for the valve cover, it will not necessarily stop the plug from firing in order, if anything it may cause a misfire but it wont stop the car from starting up. Change the fuel relay first then go from there.
jokerless06
could it have been the timing belt that broke is that y my hold light keeps flasing and it will crank just no start also my a/c compresser went out and if it locked up could that keep that belt from moving
