FS: Two K8's, mx3 blown trans, *CHEAP**abbotsford, bc*
93Colttsi
Post by 93Colttsi »
Thought i would post this stuff up for sale before i take it to the scrapyard
I have two complete K8's with the intake/exhuast manifolds attached with the TB's and injectors etc.
The first one i got from pick a part but chose not to use it because the spark plugs were out and some water got in there and rusted the cylinders up a bit. Engine still turns over and get compression and im sure would run if you put a but of oil down the cylinder and let it run for a bit. Otherwise its totally rebuildable. No bent valves or anything and it came from a car with 180 000 km's on it.
The Second engine got overheated and blew the headgasket or warped the heads. It was blowing white smoke and over-pressurizing the cooling system. Car still ran fine besides that so im sure new headgaskets and machine the heads a bit and it would also be fine. engine had 250 000 km's on it.
Have a k8 blown auto trans for parts if anyone interested.
k8 engines - $20 each
blown tranny $free
have other various parts if anyone wants them and i can take parts off the engines and sell them separatly such as manifolds, injectors, wiring harness parts, sensors, heads, valve covers, Exhaust Y pipe.
Best way to get ahold of me is to email be at:
bretthav@hotmail.com" onclick="window.open(this.href);return false;
93Colttsi
Re: FS: Two K8's, mx3 blown trans, P**abbotsford, bc*
Post by 93Colttsi »
Bump. Parts are still availible!
Everything changed to FREE if you pick it up
If I have to take parts off and ship then I have to charge a min amount.
Sleeper6
Re: FS: Two K8's, mx3 blown trans, *CHEAP**abbotsford, bc*
Post by Sleeper6 »
I dont need any atm but I would definatly save the tensioners before you toss the engines. Never hurts to have a spare, Ik the powersteering ones like to break every now and then
93Colttsi
Post by 93Colttsi »
Ya I'm going to pull off that stuff and keep it in boxes
Also have crank sensors, knock sensors, harmonic balancer, throttle bodys, intake manis and fuel injectos and rails all for a k8.
Also have a good shape clutch and flywheel from a 5speed k8
MrMazda92
Post by MrMazda92 »
93Colttsi wrote:Ya I'm going to pull off that stuff and keep it in boxes
Am I to assume the flywheel is a freebie as well?(Not including shipping)
If so, how much shipped to 97402? :)
93Colttsi
Post by 93Colttsi »
$20 for the flywheel +shipping
Email me if you want a prompt response
Bump
MrMazda92
Post by MrMazda92 »
Hmm, My plans have changed slightly for my build; You should have NO problem unloading flywheels on ProbeTalk or MX6.com though, the KL Flywheel is a beast. They'd buy it fairly quickly I imagine.
mitmaks
Post by mitmaks »
I'm looking for front bumper reinforcement if you have one
Lesley
Post by Lesley »
If you're parting them out, I'll take the spring retainers!!
92 Mx3 GS KLZE 5 speed
97 Dodge Dakota - Boyd rims, custom built 5.9 360, custom tranny with kevlar guts and shift kit. Too many upgrades to list.
92 Mazda 323 - winter beater
mx3 by Leadfoot Lesley, on Flickr
93Colttsi
Post by 93Colttsi »
Ya two complete k8's still sitting around
How much do the k8 flywheels usually sell for?
Also what would you pay for all the retainers if I was to remove them
Sorry no body/chassis parts. No re-bar
Anything else I should grab from the engines before I bring them in for scrap?
Lesley
Post by Lesley »
I dunno, how much work is it to remove them? If you can come up with a price to make it worth your time, let me know.
