The Easy Way
A forum for discussions regarding the MX-3' transmission. Swap, technical, and troubleshooting info should be placed here.
911InsideJob
The Easy Way
Post by 911InsideJob »
I plan to replace the clutch and flywheel (8lbs) when I do my swap. So I am going to ask, how tight of a fit is it when you drop the KLZE in? With the transmission already bolted on. I plan to pull the K8 with the tranny attached also. Will it fit when it goes back in with the larger KL?
Thanks all, Chris
Re: The Easy Way
a KLZE is the exact same size as a K8. Externally they're pretty much identical and for installation you would literally treat it as a K8.
Return to “Transmissions”
