mx3autozam - 93 SE Turbo ----New pics Boost is here!
nightstalker
Re: mx3autozam - 93 SE Turbo ----New pics Boost is here!
Post by nightstalker »
Man, those pics made me do something bad in my pants :oops:
mx3autozam
Post by mx3autozam »
RS_OBD'oh_2 wrote:are you putting your bumper support back on?
I sure am.
93 Mazda MX3 KLZE Turbo
killaPANDA
Post by killaPANDA »
props to u my friend that is very clean lovin the photo shoot
DeadMaker
Post by DeadMaker »
mx3autozam wrote:Here are some pictures from today.
These seats are mazda oem seats?
Black Mazda Mx3 Rs 1997 B6DE
Ryan
Post by Ryan »
that dent in your hood is so out of place...
I want to ask as I don't see anywhere that you have a LSD. I find with my car (JBeef mobile) having a very strong ZE keeping the power under control and transfering that power to the road is difficult (wheels spinning) without an LSD so having the additional power from the turbo do you plan on installing a LSD?
4gethonda
Post by 4gethonda »
my god i need to stop coming on this forum, you guys make me want a mx3 soooooo bad
god i absolutely LOVE your car
AaronTietje
Post by AaronTietje »
Very clean. I like it! My build will look quite a bit like yours when I finally get it done. :D
mx3autozam
Daninski wrote:I want to ask as I don't see anywhere that you have a LSD. I find with my car (JBeef mobile) having a very strong ZE keeping the power under control and transfering that power to the road is difficult (wheels spinning) without an LSD so having the additional power from the turbo do you plan on installing a LSD?
I used to have an LSD. I had a Phantom grip with a welded diff pin that I got from slammedsix on this forum. I was having shifting problems and ended up swapping a oem tranny back in the car but ended up being later down the road it was my slave/master going out. I found the car was able to do corners alot better with the LSD, the straight line traction I was able to still spin the tires. The best way was some really good tires
Currently I am workin on hunting down some jdm lsd mx6 axles an running a 4.11 geared mx6 with lsd.
John has a MX-6 JDM lsd tranny but once again no axles. Someone need to import those.
There must be JDM parts stores in Japan right so why can't we just order stuff like those axles from Japan? Wakari Masen
