Checking Fluid
A forum for discussions regarding the MX-3' transmission. Swap, technical, and troubleshooting info should be placed here.
anjin1982
Checking Fluid
Post by anjin1982 »
So i wanna just make sure...92 rs auto....run engine in park till warmed up....pull it wipe it then re-insert the dip-stick and check again and it should be between the warm markings which is the higher of the 2 sets...correct?
http://members.cardomain.com/anjin1982
Maintaining my MX-3 in it's natural beauty state...Although i love the modded one's!!!
Newfie_dan
Re: Checking Fluid
Post by Newfie_dan »
you can drive it to warm it up, just make sure that you let it sit at idle for a min or 2 run through all the gears, P to 2 and back then check it with the car running and it should sit where you said on the dipstick.
anjin1982
Re: Checking Fluid
Post by anjin1982 »
Thank Newfie_dan i just wanted to make sure cause my tranny was slippin abit but then i realized my cooling lines were rotted out and now that its fixed and assuming the fliud re-filled cause its shifting smoothly
Newfie_dan
Re: Checking Fluid
upgrade the cooler as well if you want to get the most life out of it.
Return to “Transmissions”
