The short of it:
Straight-neck 31-cammed ZE (Millenia IM/TB). Are valve cover gaskets for a PGT or MX-6GT or etc the correct fit?
My signature detailed rambling:
So... my mechanic uncle ordered a seal kit (likely generically for Mx-3) after my valve job. Couldn't use the IM gaskets among other things, and the VCGs in the kit seemed a little off. Now I know they are. Years ago I'd have known exactly what I needed, but a few maintanence-free years causes cobwebs. I could prob get a pic if necessary, but I know I'd just picked a set up (with good fitment) from a local parts store in the past. Any help would be appreciated.
Thanks, gurus!
Easy One: which VCG for ZE?
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
- PATDIESEL
Re: Easy One: which VCG for ZE?
The VCGs are the same for KLDE, KLZE and K8. So if your are a little off it is because they are F-ed up.
Intake are different between K8, DE and ZE. Use Millenia ones for ZE.
Thanks for clearing cobwebs, PAT. That makes sense; they seemed a little cheap. I'll pick a new set up like years ago.
And thanks for your input, Dan. Because of the spacers I'll be getting another set of paper IM gaskets from Outlaw - already on their way.
I miss you guys.
I miss you guys.
