Ford Racing ZX2 struts
Ghostcloak
Post by Ghostcloak »
It's time to get rid of the old struts in my '93 RS. I was going to go the KYB GR2 route, but then I found these for cheaper:
Ford Racing Escort ZX2 Tokico Strut Kits
http://www.summitracing.com/parts/FMS-M-18000-Z2/" onclick="window.open(this.href);return false;
Now I know that these will fit a '93 GS... And GS suspension fits on an RS with no issues... So theoretically, these Ford ZX2 struts will work on my RS with no issues right?
JWMX3
Re: Ford Racing ZX2 struts
Post by JWMX3 »
Right
thats a great price for 4 struts :shock:
Muzzled
Post by Muzzled »
i paid 304 Canadian plus change for mine. right from the ford dealership. >_<
92, Gs-Ze. KL31 motor/curve neck IM, Cai,Chipped ecu,awr mounts,clutchmasters stage 2 "R",
Se interior,Wrap around spoiler, oem full sides and MS front bumper :)
umcamara
Post by umcamara »
There is a slight modification necessary for the front upper spring perches if you use the MX-3 perches. If you use ZX-2 perches there's no mod necessary. Make sure you read the FAQ somewhere in the FAQ section first. The ZX-2 metal thrust bearings are also highly recommended versus the plastic/nylon Mx-3 ones.
'96 Silver Stone Metallic MTX RS
'98 BMW 328is M-Tech
Feedback Thread
DeadMaker
Post by DeadMaker »
Do you know if this store sells the upper bearings or the upper pearch mounts??
Can't go in this site..Connection problem
Black Mazda Mx3 Rs 1997 B6DE
Muzzled
Post by Muzzled »
just for information purposes the mx3 thrust bearings wont fit over the zx2 shaft or whatever you wana call it.
you need the zx2 thrust bearings.
id also reccomend the metal ones seeing as the plastic ones i got in the strutmount kit broke when i tried to get it around the shaft... cold days dont help much with plastic parts >_<.
ANNNNNNNNnyways. go to the wreckers and find a zx2 to pull apart. take the upper perches (guy charged me 5 bucks for the pair). and ur good to go.
umcamara
Post by umcamara »
Muzzled wrote:just for information purposes the mx3 thrust bearings wont fit over the zx2 shaft or whatever you wana call it.
Good advice. Didn't know that about the Mx-3 bearings... as I didn't even try to re-use them.
Feedback Thread
Muzzled
Post by Muzzled »
well i did buy the mx3 strut mount kits. which came with the bearings...... bearings didnt fit... soooooooo i bought the zx2 front strut mount kits (dno if the mount its'self is the same never tried)......
took the bearings out switched em and returned the zx2 strut mount kits >_< and voila :P but like i said the plastic thrust bearings suck a-- trying to install in the cold........
the one of the housings broke so ill have to replace that pretty damn fast methinks. im not driving the other mx for now.... not like itll harm it
im going to get the metal ones. i called ford though the thrust bearings themselves i think were like 50 bucks canadian....each.... cant remember they were bloody expensive though
i just installed the zx2's and H&R's on my project mx like 2 weeks ago so if you have any questions i can lend a hand :)
DeadMaker
Post by DeadMaker »
How was the ride with this setup?Cause i have this springs and with kub struts was very stiiff.
I forced to change them with oems springs
Muzzled
Post by Muzzled »
DeadMaker wrote:i just installed the zx2's and H&R's on my project mx like 2 weeks ago so if you have any questions i can lend a hand :)
i like stifff... much better than a limp spring.. :lol:
DeadMaker
Post by DeadMaker »
Which is more stiffer?eibach or HR?
Which spring will work better in this struts?
