I need Some Help!!
I need Some Help!!
Ok I was Driving Down The Interstate The otherday and i was doin around 85mph maybe 4k on the tach and my mx3 just died so I pulled over and tried starting it and it would crank but wouldnt fire ?? I havent really checked into it yet .... due to weather and shop availabilty .... but we just overhauled the 1.6 in it and it ran fine for about a month then this happened ... any ideas maybe dist. or fuel pump? a sensor of some sorts ... i know someone on here has way more knowledge of mx3's then i do ...
Re: I need Some Help!!
Welcome to the Forum!
A car dying and not starting is a pretty narrow list of symptoms... like telling a doctor you have a rash, and asking what it could be... one of a thousand things! So lets try to get some specifics
First off, is the Check engine light flashing when you try to start?
Hows your timing belt?
Any goofy sounds?
Anything else funny about it?
Any goofy sounds?
-Blaze Red 92 MX-3 RS w/ Brembo rotors, Infinity Kappas 62.9i
"MA! THE MEATLOAF!!"
Ok I did some Diagnosing of the problem.... Timing belt broke.. ya it sucks but how bad of a pain to fix since of the interference motor crap .... i havnt even pulled the head to look if the valve stems are bent ... but how good are the chances of nothing major happenin? ill prolly just do a swap now not sure... but if anyone is wanting a 94 Rs w/ 1.6 DOHC then hit me up its in good shape its lowered and has had motor overhauled a few months ago and now the timing belt broke
Your chances are about 100%. The B-Series engine is non-interference, so belt snaps, you just gotta re-align the timing marks and throw a new belt on there.krucialmx3 wrote:but how good are the chances of nothing major happenin?
Ok so The B-series motors are non interference? Cuz i called a local mechanic for advice and he said it was ... but i was thinkin he just didnt wanna mess with it ....??? so i just need to put back into time and new belt? sounds good? any opposers to this ??
- Ryan
definately non-interference.
Just re-belt it. make sure timing is on before putting the covers back on.
Can Someone Explain the steps to put it back into time .....Ive seen it done but this time Ill be On my own so plz anything helps thank you all...
The next 2.5 pages are all you need... just click the image to get to the next page
- Ryan
I don't know what motor you have. (SOHC or DOHC)
Line up the crank pully. Lineup the cam pullies. (E point on exhaust cam, I on intake) and then slip the belt on and put on tensioner. Do a revollution or two of the cam pullies (plugs out, wrench on cam or crank pully), and make sure everything still matches up.
- jkbreazeale
94 rs = b6de = dohc ![Very Happy :D](./images/smilies/icon_biggrin.gif)
1993 MX-3 RS (my project car) http://www.cardomain.com/ride/3815854 <- Check out my Cardomain!
1995 MX-3 RS (wife's project car)
